Home Backup with SSDs
With flash memory, you’ll back up your content faster and access it quicker. SSDs from Western Digital come with the backup tools you need to keep it that way.
Malware & ransomware
There’s a ransomware attack every 11 seconds. Invest in backup now to avoid extortion later. 
Third-party breaches
Cloud storage keeps your data somewhere else, on someone else’s server. Don’t put your entire backup in one basket.
Hardware failure
Your favorite device won’t last forever. Make sure your files aren’t collateral damage.
Human error
Nobody’s perfect. Plan ahead, just in case you accidentally delete content you can’t do without.
Plan Your SSD Backup
Don’t risk your favorite photos, footage, and files to data loss. Plan your backup, choose your SSD, and start securing your content.
The right SSD — and the right backup strategy with it — depends on how much content you want to save and what type of content you’re saving. For reference, 1TB1 of SSD storage can save one of the following types of content, up to2:
43,647 minutes of music3
138,178 photos4
150 movies5
1,935 mobile games6
900,000 minutes of podcasts7
Windows Backup with SSDs
When you buy one of our eligible SSDs, you’ll also get Acronis True Image for Western Digital — a complete cyber protection solution that will help you back up and secure your information.
You can use Acronis True Image on your Windows device to:
  • Back up documents, photos, and emails
  • Save content like music and movies
  • Archive your entire disk drive, including your operating system, applications, settings, and all of your data
Learn more about backing up your entire computer with Acronis True Image for Western Digital — or get help with installation.
SSDs for Windows Backup
VALUE
MAINSTREAM
PERFORMANCE
macOS Backup with SSDs
Our eligible Mac-compatible SSDs give you options for backing up with either Acronis True Image for Western Digital or Time Machine.
Depending on which option you choose, you can:
  • Back up selected disks or your Mac’s contents
  • Back up selected files and folders
  • Create Acronis bootable media
  • Prepare macOS recovery
  • Recover specific files and folders under macOS
Learn more about backing up your Mac with Acronis True Image for Western Digital — or get help with macOS installation.
SSDs for macOS Backup
VALUE
MAINSTREAM
PERFORMANCE
iOS and Android Backup with SSDs
Help keep your smartphone content safe by backing up on SSDs that are compatible with iOS or Android8.
With the iOS Files app and a compatible SSD, you can:
  • Support the iPhone 15 lineup’s direct HD recording
  • Get high performance and super-fast transfers
  • Free up your iPhone’s internal storage for more content
With the SanDisk Memory Zone app for Android8, you can:
  • Back up and restore your Android smartphone
  • Delete junk files
  • Clean up WhatsApp media
  • Manage apps that are taking up space
SSDs for iPhone 15 Backup
VALUE
MAINSTREAM
SSDs for Android Backup
VALUE
MAINSTREAM
PERFORMANCE
Gaming Backup with SSDs
Back up your favorite games so you can help keep your content on hand and ready to play. With external and portable SSDs, you can:
  • Archive titles without having to delete games to make space
  • Augment your favorite console’s onboard storage to save even more
  • Store DLCs and bonus content in style with WD_BLACK aesthetics
  • Customize RGB lighting on your peripherals with select products
SSDs for Gaming Backup
PLAYSTATION
DESKTOP AND LAPTOP
XBOX
Creative Workflow Backup with SSDs
If you’re a creative professional who works from home — or if you need to back up copies of your content outside the studio — make external and portable SSDs part of your backup strategy.
With Acronis True Image for Western Digital, serious creators can:
  • Back up your entire system or selected projects
  • Manage custom backup schemes
  • Customize file compression levels
  • Set backup scheduling and retention rules
Learn more about backing up your entire computer with Acronis True Image for Western Digital — or get help with installation on Windows or macOS.
SSDs for Creative Workflow Backup
MODULAR SSD WORKFLOWS
POWERFUL CREATIVE BACKUP
RAID-CAPABLE STORAGE
ssd-home-backup-feature7
Learn More About SSD Backup
Yes, SSDs are versatile enough to back up many different content types including games, videos, photos, and documents. This flexibility makes SSDs a comprehensive storage solution for your entire digital life, helping you keep the content that’s most important to you as safe and secure as possible.
2. Approximations: results will vary based on file size, resolution, compression, bit rate, content, host device, pre-loaded files and other factors.
3. Based on High Fidelity Apple/Spotify Lossless Compression: 96KHz 24-bit Audio (20.62MB/minute).
4. Based on Standard Resolution: 22 Megapixel JPEG (6.5MB each).
5. Based on Full HD Movie: 2 hours (6GB).
6. Based on mobile game (465MB each).
7. Based on Standard (MP3): 128kbps Audio (1MB/minute).
8. Download and installation required. See www.sandisk.com/memoryzone
