CREATOR
SERIES
SanDisk Creator Series helps bring your content to life so you can reach your audience and make your mark.
Your world is waiting.
GET STARTED
Fast storage for creators everywhere
To own your vision, you need to own your content. Creator Series was designed to put you in control of your every shoot, every file transfer, every editing session, and every backup.
CAPTURE
Shoot high-res video. Fill up your camera roll. Record your latest podcast episode. Creator Series helps capture what matters.
TRANSFER
Record on your smartphone or camera and offload to your tablet or laptop. Creator Series moves content quickly.
EDIT
Prep your content for primetime. Even live edit right from your Creator Series portable SSD.
BACK UP
Your creative vision is what makes you, you. Back it up so it's accessible and shareable with Creator Series drives.
ADOBE PARTNERSHIP
Purchase any device from the Creator Series and get a free trial of select Adobe Creative Cloud products.* Check out what tools you’ll get based on which Creator Series product you buy.
CREATOR WORKFLOW
For iPhone
USB flash drive for transferring
Capture content on your compatible iPhone. Then, use SanDisk Creator Phone Drive to transfer files to your tablet or computer for editing.
Portable SSD for editing
Record on your iPhone 15 series device. Save content for later on SanDisk Creator PRO Portable SSD or upload it elsewhere with NVMe™ speed.
External SSD for saving
When you’re ready to back up footage or save edited content, SanDisk Creator Desk Drive delivers up to 8TB of fast NVMe™ storage.
CREATOR WORKFLOW
For Android
microSD for capturing
Make space for high-res content on your Android smartphone with SanDisk Creator microSD Card.
USB flash drives for transferring
SanDisk Creator USB Flash Drive for transferring smartphone content fast.
Once you're ready to edit content, store it on SanDisk Creator PRO Portable SSD with rapid read/write speeds.
CREATOR WORKFLOW
For Drones & Action Cams
Capture even more eye-popping footage on your drone or action cam with SanDisk Creator microSD Card.
Upload content from memory cards to your computer in the field. Then, edit, transfer, and save it to SanDisk Creator PRO Portable SSD.
Back at your desk? Transfer content to your workstation from your memory cards or portable SSDs to your main computer. Then, when you’re ready to back it up, use SanDisk Creator Desk Drive for high-capacity, long-term storage.
CREATOR WORKFLOW
For Digital Cameras
Ready to prep your content? SanDisk Creator PRO Portable SSD is fast enough for live-editing right from the drive, so you can get your files from raw to ready in a flash.
BACKUP SOFTWARE
SanDisk Memory Zone
SanDisk Memory Zone 2.0 is the easiest way to back up data to SanDisk devices and make space for new content.* Save it on here and share it out there — right out of the box.
Connect your drive
Set your backup
Keep your content safe
Coming soon for Mac & PC:
  • • Back up files
  • • Create folders
  • • Encrypt content
  • • Browse your backups
  • • Manage, move, or copy files
  • • Customize your drive’s settings
* Limitations apply. See product page for details.
2. Download and installation required. See https://support-in.sandisk.com/app/products/downloads/softwaredownloads
